Panel Door question.
Old 07-24-2010 | 09:48 PM
Rikki Sixx's Avatar
I've always had a little trouble with the rear drivers side door on my '08 Panel. I have to push the button two or three times to get it to pop open. Never had that problem with the passenger side door.
Any adjustment I can make or is it a dealer fix only?
Old 07-24-2010 | 10:34 PM
American & Proud's Avatar
Rest In Peace
On my '08 Panel If I hit the button Once, it slightly opens, hitting it a Second time seems to Pop them open further. On Both sides.
If your under Warranty still have it looked at, and see what they say.
< Havent Yet, But, Reading the Manual may give the Answer?
Old 07-24-2010 | 10:39 PM
oneton's Avatar
The hole might be a little tight not letting the knob pop up. There is a post on here somewhere. Try trimming the hole to make it a little bigger.
Old 07-24-2010 | 10:44 PM
Rest In Peace
Honestly, I thought it might be a Safety Feature.
Old 07-25-2010 | 08:26 AM
I don't think the OP is referring to lock knob. Remember, panels have the poppers for the rear doors and I'm sure that is what this thread is about.
Old 07-26-2010 | 12:45 AM
Do you get the same result from the key fob button, as well as the dash button ?
If it's just when using the key fob, well you know the rest..
Old 07-28-2010 | 12:14 AM
Marzipan's Avatar
Page 2-6 of the Owner's Manual tell us how to open the Panel's rear door. It is not as simple as just clicking the FOB button.
Old 07-28-2010 | 09:11 AM
ChevyMgr's Avatar
They may need to do this:
https://www.chevyhhr.net/forums/show...hp?p=345279#20
This fix works by my experiences.
Old 07-28-2010 | 09:17 AM
diskullman's Avatar
I have the same problem with having to click 2 or 3 times. Time to get some washers
Old 07-28-2010 | 11:13 AM
TEB-HHR's Avatar
this should help, will need to try
