Possible cooling system leak?
Hi,
I had a sudden overheating problem in my 2010 HHR. After turning off the engine, the fan continued to run. I turned the car on to see the temp gauge nearly go to red. I turned it off, let the engine cool, opened the coolant recovery tank, and found no coolant. This happened very suddenly! Could a leak have happened suddenly? Should I try to refill the tank if there is a leak? I don't want coolant to drain on the ground.
SSROADSTER
43
03-07-2022 08:46 PM
Mackey14
11-30-2011 07:10 PM
