Is it possible to reverse the VVT sprockets?
Old 01-26-2021 | 06:24 PM
  #91
TruckerKevin's Avatar
Well, this is the way the story went
I bought the car with a thrown timing chain. The shop it was towed to told the previous owners that it needed a valve job because of the thrown chain. I bought it as is in that condition and towed it home.
I was fully expecting to do the head. When I got it all apart, I was really surprised that the valves all looked fine to the naked eye. Only the timing chain guide was broken. The chain was still intact. In retrospect, I could probably have just replaced the chain and been on my merry way. But,,,,, how was I really supposed to know. I would have at least had to do a chain to do a compression test, right?
Since I was into it that deep, I decided to take the head to the local machine shop that’s everyone praised up to me. I just wanted them to look at it. It was the day before New Years. I did not hear anything from them for 6 days (3 of them being New Years holiday weekend). I finally went there to see, and they had the dang thing apart and had done a valve job on it.without even calling me. And said they were waiting on me to bring them seals. Doh. Okay, I ran home and got the seals.
So the next day when I was paying, I noticed on the invoice it said R&R cams, $40. I asked about it, and he said if I had removed them it would have saved me $40.
Being naive, trusting, or just dumb, I just assumed they put everything to spec. Including torquing the cams. Then I found the VVT sprockets were reversed, hence I made this thread. If I hadn’t been so eager to get this thing together and just slowed down, I would have caught all of that. Teaches me to take it slow and easy.
I almost didnt catch this problem today. Honestly, I was getting ready to pull the head again. I just so happened to look at the shavings, and when I picked one up I noticed the intake cam move a little. The right 2 journels were finger tight. The exhaust cam wears good. Looks like they got it half together and got distracted
So yeah, that was long winded. I am just freaking happy I got this solved. ANd the car really runs super great too!
Old 01-26-2021 | 07:07 PM
  #92
A long and winding road to a good final result.
Old 01-26-2021 | 07:46 PM
  #93
They would have had to remove the camshafts to get to remove the valve seals which live under the valve springs and retainers and keepers, trust me it’s not a fun job without the right tool to compress the valve spring . $40.00 a good amount depending on shop rate is equivalent to 1/2 hour to R&R the camshafts, sadly they didn’t do it fully and correctly.
Keep it clean, drive it often!!
dmczeal
2.4L Performance Tech
13
08-08-2020 10:03 AM
Dasstrum
Maintenance and Upkeep
16
02-19-2017 01:45 PM
aradmahogany
07-10-2016 03:43 PM
MiamiHHR2012
2.2L Performance Tech
22
06-07-2012 11:26 AM
austingrackle
11
10-21-2009 11:29 AM
Quick Reply: Is it possible to reverse the VVT sprockets?
