Power mirrors
Power mirrors
I've searched for problems with the power mirrors. Both of my mirrors on my 09 stopped working at the same time. Today I changed the 5amp MIR fuse (#21 I believe) and replaced the mirror switch......still nothing. Am I missing something, is there another fuse perhaps? Strange that they both should quit at the same time.....if anyone has any insight into this problem, I would surely appreciate your input.....Thanks.
Yes I guess that there probably is no power to the switch for some reason. I thought it might be a simple solution like a relay that needed to be replaced, or a bad ground somewhere that needed to be cleaned. I'm waiting for the parts to become available for the ignition switch recall, they will call for an appointment, I'll have them look at the mirrors at the same time.....better that me fiddling with the wiring or worse. Thanks for the help.
Had that same problem on my niece's Saturn Sky and it ended up being the 7.5A BCM Elect fuse as power for the mirrors comes from the BCM. Not sure if HHRs are set up the same way but much of the electronics are similar.
I case you don't know the BCM is behind the cover on the right side of the console to the left of and below the glove compartment. Pull that cover and you'll see the fuses on the upper portion of the BCM.
The diagram only shows the mirrors getting it's power feed from the underhood fuse block. 5 amp fuse .
Just about every other thing in the HHR operates thru the BCM, (according to the diagrams), including the cabin rear view mirror. Odd that the side mirrors don't.
Taken verbatim from the 2009 HHR service manual:
Outside Mirror Description and Operation
Power Mirror System Components
The power mirror system consists of the following components:
• Mirror direction switch -- Controls the left, right, up and down movements of the mirrors
• Mirror select switch -- Allows the operator to select the mirror to be moved
• Left outside mirror -- Contains both the horizontal and vertical mirror motors
• Right outside mirror -- Contains both the horizontal and vertical mirror motors
• BCM ELECT 7.5A fuse -- Located in the body control module (BCM) fuse panel and supplies power for the power mirror system
Each of the outside power mirrors contains 2 motors. The up-down motor operates the vertical directions and the left-right motor operates the horizontal directions. Each of the power mirror motors are internally circuit breaker protected.
Odd. I'm looking at the 2008 repair manual schematics.
Under the Power Mirrors section it shows the schematics for the both the side mirrors AND the interior rear view mirror.
Shows the interior mirror with a 10 amp feed from the BCM. Shows the side mirror feed from the 5 amp underhood fuse. No BCM connection.
Wonder what is correct here.
