Power steering
Old 11-02-2018 | 04:55 PM
Now I am lookng at a different year for the c0550 code, completely different. evidently when it says control unit they mean any control unit. C0550 39 means a checksum mismatch in the EEPROM
The 2009 page says it is a EBCM error involving the Power steering control module. It would cause ABS light, TC light, BRAKE light, pwr steering on DIC.
The PSCM inputs to the EBCM to do the TC and ESC and ABS stuff.
Old 11-02-2018 | 05:52 PM
guppy's Avatar
Soooo. Sounds like I need a PSCM (steering column)?
Old 11-02-2018 | 05:59 PM
Seems like it, since the shop said it and the TSB said it. Give hellshotrod a PM, he has a bunch of them.
Old 11-03-2018 | 03:23 PM
guppy's Avatar
So apparently it makes a difference if I have active brake control (option JL4). I assume mine does not?
Old 11-03-2018 | 03:54 PM
You don't have JL9 or JM4 ABS either, so I'm guessing it is included in 1LT. You have a ESC or Traction Control button?
Where did you see that?
Old 11-03-2018 | 05:03 PM
  #26
J41 seems to be non-ABS brakes.
Old 11-03-2018 | 06:45 PM
  #27
ABS is standard 2009 onward. AHA, your VIN says the car is a 2008!
However, the TSB still applies.
Part number seems to be the same.
Old 11-07-2018 | 08:24 PM
  #28
guppy's Avatar
I found a couple steering columns at a junkyard ($80). They are missing the key, which I think will be fine, since I have about three spares already made up for my car. How hard is it to change the ignition switch (No key)? The junkyard does have one column with a single key, but I will definately have to change the airbag and possibley the steering wheel. These columns come with steering wheel, PSCM and power assist motor. I am actually kind of excited about getting all the spare parts. Should the ignition switch pose any issue or is it just screwed on?
Old 11-07-2018 | 09:35 PM
  #29
You need the key to remove the cylinder to transfer it (Or makes it a lot easier). You will also need to transfer your security module.
No reason to need a new airbag or steering wheel.
Old 11-07-2018 | 11:11 PM
  #30
guppy's Avatar
So I want to remove ignition/security module and throw it in the trash. Then remove the ignition and security module from my HHR that has a key and out onto junkyard csteering column. Can I remove the igniton/security module off the junkyard keyless steering column?
