Power steering
Old 08-22-2019, 06:36 PM
SuzB71's Avatar
Power steering
Ok so I Was driving down the road and my power steering Went out I pulled over turn the car off and restarted it . The power steering was fine. It did this a couple more times in the next few months and this morning it's out and won't come back on. Any suggestions?
SuzB71 is offline
Old 08-22-2019, 06:42 PM
More than likely it's the power assist motor and there is an extended warranty on that part (Don't use the word recall)
Greybeard999 is offline
Old 08-22-2019, 07:15 PM
X2. Just contact your dealer as they will replace the motor at no charge. Have your VIN number handy as they will need it to check on the warranty status.
Did you not get a letter from GM regarding the extended warranty for the steering motor?
whopper is offline
Old 08-22-2019, 07:42 PM
FYI. Doesn't matter the year, mileage or original owner or not because for now it is an extended lifetime warranty.
Contact your local dealer as noted above.
firemangeorge is offline
Old 08-22-2019, 09:18 PM
If it's an SS, then there's no warranty.
RJ_RS_SS_350 is offline
Old 08-24-2019, 06:44 AM
SuzB71's Avatar
I bought the car wrecked from an auction. Would the extended warranty still apply?
SuzB71 is offline
Old 08-24-2019, 06:53 AM
Probably not if it's got a salvage title. But, you could contact a dealer and ask.
Old 08-24-2019, 08:50 AM
SuzB71's Avatar
Thank you so much. Since I'm here I have another question. Every now and then when I'm driving my abs light on the dash comes on. Along with the squiggly car light. The dash computer thingy will say service traction and esc is off. Then after a bit it goes back to normal..
SuzB71 is offline
Old 08-24-2019, 06:40 PM
A bum hub or cam shaft solenoids, there should be codes for that.
a low voltage battery will also do that or loose ABS connections at the hubs
Oldblue is online now
Old 08-26-2019, 01:54 PM
SuzB71's Avatar
Thank you. I called the dealer this morning and gave them my cars vin #. They told me there were no extended warranty or recalls. But ya, even if there was they wont touch a salvage title. So stupid. Only damage was cosmetic. Even still, it shouldn't matter. Anyway, thank for the help .
SuzB71 is offline
Quick Reply: Power steering
