Power Steering/Service Air Bag Message
Old 02-08-2014, 06:02 PM
tucsondivots's Avatar
After starting my 2010 HHR this morning I got a message "Power Steering" in the DIC. Sure enough, the steering wheel would not budge. Turned it off and restarted. This time no warning about Power Steering, but a message "Service Air Bag". Steering Wheel turned like normal. Seatbelt icon stayed on as I drove away. Stopped and turned engine off and back on. The Service Air Bag message disappeared, no Seatbelt icon and all was well the rest of the morning commute. The only thing different from any other day is I did not start or drive the HHR yesterday. Any ideas what this is? I just made sure all the fuses were seated properly. Some were not completely pushed in. I am not sure if this is something that could result in my Power Steering going out while in motion.
tucsondivots is offline
Old 02-08-2014, 06:45 PM
Probably not. But, check to see if the 2 halves of the fuse box are properly mated. Also, check the nuts that connect the 2 cables to the fuse box, the RED one is battery + and the BLACK one is Power Steering.
donbrew is offline
Old 02-08-2014, 07:15 PM
Hello tucsondivots,
It's a bummer to hear about the different warning messages you experienced today. If this is something you are planning to work with your dealership to have diagnosed, please let me know and I would be happy to offer my support throughout the process. I can be reached via PM.
Kind Regards,
Jonathan A.
Chevrolet Customer Care
ChevroletCustomerService is offline
Old 02-08-2014, 08:14 PM
Lucky's Avatar
I agree with don check the battery cable connections. I found mine loose and it would make all kinds of strange things happen. You may also want to get the battery tested a failing battery can cause this also.
Lucky is offline
Old 02-08-2014, 09:42 PM
The battery is only 5 months old, but I did think it turned over a little slow (did not drive the day before).
Old 02-08-2014, 09:43 PM
Great, I will check this.
Old 02-09-2014, 01:55 AM
That's usually my first clue to check my battery and all the connections - and if the battery gets drained a little, or is on the low-charge side, all sorts of weird electrical things happen to these vehicles.
ie: I left the doors open for 3-4 hours with the interior lights on while I was changing door handles, and when it was started the next day, it took two tries to get it to fire up, and the instrument panel light up like a Christmas tree, along with running REAL rough. I took it for a 5 mile run, and it has been fine since. "low battery"!!
whopper is offline
Old 02-11-2014, 08:41 PM
All fuse box connections were tight. This is a 5 month old battery, but I wonder if that is the issue. I did not start it for one day prior to the dic messages. I usually drive it everyday, but hate to think it would drain if parked at the airport for several days. Can Autozone (where I bought it) determine if it is not holding a charge properly?
Old 02-11-2014, 09:01 PM
Yes, the auto parts store should be able to load test the battery for you.
843de is offline
Old 02-12-2014, 07:16 AM
My new battery will die if I leave the door open for a couple of hours to. Headlights kill it in about 20 minutes.
donbrew is offline
Quick Reply: Power Steering/Service Air Bag Message
