Power steering stops while I'M driving
Why would my power steering just stop as I am driving and then after I put it in park and restart the engine reset and then turn off again? I already replaced the fuse for the EPS.I have a 2009 HHRLS, This happened 4 times today and I never had a problem with this car in 4 yrs...I love my HHR.
I have the same thing on a 2006. Power steering does not work. it would work if I pulled the fuse and put it back in. Now it out 100% of the time. I searched for answers but there is not a clear concise solution I have found. If some one has found a solution please post.
Actually this has been discussed a lot previously - it's your power steering motor that needs replacement. There is a "How-to" article on replacing it - it's a good writeup - and is easy to do, and the parts are cheap.
Thank you
Jessica L.
Chevrolet Customer Care
In canada this has been addressed by a special 10yr replacement plan on some vehicles by VIN, US may be different. The electric power steering motor has a thermal shutdown feature, when the motor gets too hot it shuts off temporarily. This may be due to failing motor.
Could you send me the link. I searched and looked at some possibles but nothing was clear to me on what needed to be done and with what parts.
