Power Window Question
Before you post I should read other posts hear me out.
Intermittently and happens to every switch I can roll down the window every time but when it comes to rolling up sometimes it works and sometimes it don't.
If i push down and then up really quick it works more often.
from this I know the fuses are not blown so can every window or switch be bad?
front and back Every thread I read (quite a few) they talk about just the rear or on switch or nothing works period. This is getting frustrating the other day it took 30 minutes to get the window up.
motor has no hesitation when it does work.
and yes I made sure the rear safety switch wasn't engaged
any and all help would be great.
Thank you all in advance
what year HHR do you have the switches in my '07 are in the console, they where moved to the drivers door in '09 , have you spilt any beverages on the switches??
and read this post
www.chevyhhr.net/forums/showthread.php?t=46384
and read this post
So they are drivers door mounted, have you checked the voltage on your battery? at 5 years old if it is the original battery could be low voltage causing electrical gremlins to wake up, just don't get 'em wet!!
