Presence de glace dans collecteur d admission
Old 01-31-2013 | 07:35 AM
tremor1966's Avatar
Bonjour,
je suis de chicoutimi je possede un HHR moteur ecotec 2.2L voici mon probleme : code moteur p0121 throttle/pédal position sensor/Switch "A"circuit range/performance , alors je fait mon trouble shouting et rien a signaler je decide donc d enlever le throtlle body et a ma grande surprise il est geler par le froid cela provient du tuyau du vent du crankcase breather et avec 1 pouce de glace dans le fond du collecteur d admission (intake manifold) alord je me demande comment remedier a ca et si vous avez deja vue ca
merci
Old 01-31-2013 | 07:55 AM
tremor1966's Avatar
Throttle body frozen at -30C
problem with my HHR 2007 ECOTEC 2.2L throttle body and intake manifold frozen in -35c there is in 1" ice on down. Have you an idea to correct this probleme
I think that the probleme results by an moisture on engine !
Thanks
Old 01-31-2013 | 08:58 AM
db/sb's Avatar
Does your HHR have an engine block heater? Not ever sure if that would help @ -30°C. Being from somewhere that lowest tempeature we see is about 30°F (about -1°C), I have to ask: do people really drive in that type of weather?
Old 01-31-2013 | 10:28 AM
HipHotRod's Avatar
For us stateside folks.....
Originally Posted by tremor1966
Bonjour,
merci
HelloI'm from chicoutimi I owned a HHR engine ecotec 2.2 L here is my problem: engine code p0121 throttle/pedal position sensor/Switch "A" circuit range / performance, so I made my trouble shouting and nothing a report I decided so d remove the throtlle body and to my surprise it is freezing cold this stems from the hose of the wind and the crankcase breather with 1 inch of ice in the bottom of the manifold intake (intake manifold) writing I wonder how correct a ca and if you have already seen ca
Now help this dude!
Old 01-31-2013 | 11:17 AM
ChevyMgr's Avatar
Threads merged. No idea on help. Electric blanket?
Old 01-31-2013 | 12:17 PM
Snoopy's Avatar
tremor......
That would be a GREAT question for a GOOD GM dealer, who should contact GM/Chevrolet Engineering with the question.
I know they would be extremely interested.
GM/Chevrolet tested these cars and engines in Kapuskasing (spelling?) and didn't have that problem....or maybe they did!!
Old 02-04-2013 | 02:27 PM
tremor1966's Avatar
I think to find a problem the previous owner did not maintenance this car , to result clogged with mud white on valve cover , i have clean valve cover and 2 flush engine and return normal
Rej
Canadian North East
01-17-2017 03:33 PM
Appleton
Canadian North East
12
02-04-2010 12:20 PM
AlphaJaguar5
South East
04-04-2008 08:20 AM
dan-d
South East
12-05-2006 09:05 AM
Quick Reply: Presence de glace dans collecteur d admission
