Pressure switch for AC
Here's the location on an LNF. I don't understand how your going to change it without vacuuming the system. Is there a valve in the orifice where it mounts? Some vehicles are set up that way. I haven't changed one on an HHR.
On all other cars (GM and others) on which I changed pressure valves, it screwed onto a Schrader valve (looks like a tire valve or fuel pressure test valve).
The picture of the new pressure switch above looks like it also screws into a Schrader valve, but I can't tell for sure.
Why do you suspect a bad pressure switch? If you were sure there was enough refrigerant in the system,and the compressor doesn't come on, jumpering across the switch to engage the compressor clutch would show if it was bad or not. You have to be sure there is enough refrigerant in the system, otherwise the test would only show the switch was doing its job correctly.
Steve
Steve
Steve
Steve
The only reason I mentioned that is because the GM HHR service manual talks about recovering the refrigerant as part of the process and, as I stated, I've not done this on an HHR. I've worked on many systems (see bottom line in signature) including late 70s to mid 80s Nissan/Datsun and other Japanese vehicles that didn't have a schrader valve behind the pressure valve so, in my experience, I wouldn't say "all" other cars.
Two things; I'm fairly certain that the HHR does have a scharader valve there based on fastsuv's comment, a little research, and a couple of people I've asked. And based on what you've said I don't think you have to change it anyway. Just have a shop remove some of the refrigerant with a recovery machine until it's within range and you should be okay.
db/sb
I've yet to do anything to it yet but when sitting at idle when the compressor is on and blowing cold, there's a loud humming/revving noise sounding like it's coming from the condenser I just replaced. Does that sound like something you've heard?
