Pressure switch for AC
Old 06-21-2014, 03:58 PM
db/sb's Avatar
Never heard a sound like that on an HHR. The only time I recall hearing anything remote like that was on my 90 Ranger but the sound was coming from the compressor.
db/sb is offline
Old 06-21-2014, 09:48 PM
toolbender's Avatar
Originally Posted by Bigpatshhr
db/sb
I've yet to do anything to it yet but when sitting at idle when the compressor is on and blowing cold, there's a loud humming/revving noise sounding like it's coming from the condenser I just replaced. Does that sound like something you've heard?
With the vehicle off, blow air through the condenser. If you can replicate a similar sound, you have loose fins or possibly debris stuck in the fins.
toolbender is offline
Old 06-23-2014, 08:55 PM
Bigpatshhr's Avatar
Finally found the problem. Changed out the pressure switch anyways since I had to get in there. On my SS the inter cooler piping was changed to an aftermarket which is apparently bigger than stock. There is a vacuum tube and sensor at the bottom before entering into the inter cooler which is pushed tight against the factory pressure switch plug and has rubbed a wire bare. We separated the wires and siliconed it up and it works great now. Will fix it the right way later when I take off the front end to install new. Thanks for all the help.
Bigpatshhr is offline
alfolsee2000
05-30-2016 08:23 AM
Harpman
07-27-2015 08:09 AM
dodger542000
Tires & Wheels
09-06-2012 09:14 PM
Nukundu
08-18-2010 01:16 PM
andoll83
03-23-2010 06:25 PM
Quick Reply: Pressure switch for AC
