Problem starting
Problem starting
turn key to on step on brake and turn key to crank and nothing lights on dash go out like cranking over but nothing . can hear a click on body comp below radio and can feel it click but nothing. Battery is fully charged and new. Any ideas would be appreciate thanks G bonnes
Automatic trans ? Wild guess here. Try putting the trans in neutral. If that doesn't work, try wiggling the shifter in park while trying to start.
It may be the neutral safety switch ( or whatever the technical name is)
