Problems already....
Old 08-14-2013 | 06:33 PM
Ghost09's Avatar
LMAO i'm pretty sure i'm a little smarter than that haha, i'll let ya know how it goes, doing the rotors tonight, bought rotors from napa and they seem pretty beefy! I was surprised how heavy and thick they are compared to my S-10 drilled and slotted rotors!
Old 08-14-2013 | 08:27 PM
Keep the receipt from NAPA, as they probably have a lifetime warranty on the rotors. NAPA has treated me pretty good here.
Old 08-15-2013 | 04:41 PM
Ghost09's Avatar
Got the rotors all changed, really quick and easy! WAY easier than my S-10! Been driving all day and it feels like a new car again! LOL All for $150, saved myself almost $500!
Old 08-15-2013 | 05:19 PM
Good deal!!! Yeah it takes me longer to jack up each corner and re and re the wheels than it does to replace the rotors.
Hopefully you adjusted to rear brakes? 3-4 clicks on the emergency brake should be about right. If you didn't adjust them, a lot of people here have found that the front brakes are doing most of the work, and end up with warped rotors quite quickly.
Old 08-15-2013 | 05:20 PM
ronp's Avatar
Just did my rotors and ceramic pads rotors were 40 each pads covered by lifetime warranty autozone....last set went 100.000 miles they still had half pad left.
No more jumpy wheel lol
2009 hhr 220,000 no repairs yet runs new
Old 08-15-2013 | 05:29 PM
  #26
Depends on the manager on duty at the big box stores. Technically It does say Defects, not normal wear. My local guys got smart after 3 or 4 times.
I am starting to think that my rear brakes are the juddering problem, seems that it goes away after I adjust them up correctly. But then, it goes away for a time no matter what I do (struts, shocks, sway bushings, LCAs, rotors, pads) then pops back up right after I sez to myself "you are a smarty pants".
Old 08-15-2013 | 05:33 PM
  #27
Ghost09's Avatar
No i didnt adjust the rears, i hate drums so i dont touch them LOL but the e-brake goes about 4-5 clicks so i think i'm ok...? Might get the family mechanic to make an adjustment for me
Old 08-15-2013 | 05:47 PM
  #28
Hate 'em all you want! Problem is: you got 'em! If you don't tend to them, they will bite you.
Self adjusting rear drums on cars with front disc brakes HAVE NEVER WORKED right. I might even go so far as to say even on 4-wheel drum systems of yore, if my memory was better.
Old 08-15-2013 | 05:58 PM
  #29
Ghost09's Avatar
Haha ya i know....I figured i would just let someone who works on them everyday deal with them, i've worked on them before, just had a hard time with them
4 wheel drums.....been a while since i've seen those! LOL
Old 08-15-2013 | 10:15 PM
  #30
IgottaWoody's Avatar
Just do the drive in reverse and apply firm brakes a few times for a quick adjustment...most the problem is these cars dont get backed up enough fir proper adjustment...it takes a bit more then a crawl backwards with a babytap brake to keep em adjusted. Applies to rear drums only...
Quick Reply: Problems already....
