Problems with the breaks on my HHR
Old 08-03-2019 | 08:55 PM
cmsharkey1's Avatar
Originally Posted by Lonwane
Did you bleed them to HHR specs (RR, LF, LR, RF) or the old way (furthest first, closest last)? There is a difference
We didn't. Would that cause the problem to happen some time later?
Old 08-03-2019 | 10:37 PM
There is a hose from the intake manifold to the brake booster. Make sure it is connected at both ends, no holes.
The check valve is the plastic part that the hose connects to on the booster end. It is supposed to allow air flow in one direction only.
Calipers slide, sometimes they stick. If the inner pads were worn much more than the outers is clue.
50% wear on the rears is way worn out. Adjustment is the question here though. The "self-adjusters" are not good enough.
Are there any warning lights or warnings that you are not mentioning?
You should get the OBD read, there could be some codes that do not cause a CEL.
Old 08-05-2019 | 09:04 PM
Maybe take it to a competent mechanic... Brakes are nothing to play with..
Old 08-06-2019 | 06:55 AM
aradmahogany's Avatar
Might be an issue with the abs module as well
Cat Man HHR
03-20-2019 07:30 PM
jburton7379
01-07-2011 10:52 AM
vschriver
06-13-2008 07:57 AM
iowapk
09-20-2007 09:36 AM
joesblackhhr
10-04-2006 01:55 PM
Quick Reply: Problems with the breaks on my HHR
