Questions about CEL O2 Sensor Codes
I now have a '09 2.4L LT2 HHR with almost 80,000 miles. (My other one was totaled in May when I collided with a suicidal deer in May.)
Today while driving on the highway the CEL came on. I stopped off at O'Reillys and asked them to pull the codes. Here's what they told me
P0138 HO2S Circuit High Voltage Sensor 2 (Bank 1 sensor 2 intermittent)
P013E HO2S Delayed Response Rich to Lean Sensor 2 (Bank 1 sensor 2) They said this one had been on 3 other times.
P2271 HO2S Signal Stuck Rich Sensor 2 (Bank 1 sensor 2 intermittent)
I am able to do a lot of repairs etc on the car myself and with a little research I'm sure I can figure out how to replace the O2 sensors if that is what the problem actually is. I know I should check the flex pipe for cracks. What other things should I check?
the big thing though I need to ask is I am supposed to make a 600 mile trip on Monday ---30 hours from now. I doubt very much I could get the parts in time to get this fixed before then. Should I cancel the trip? If I do go what risks am I taking?
Thanks for any help!
I may have an answer to the big question if I make the trip or not. If there is a question that the flex pipe is involved and it might be covered under the 8/80 emissions warranty, it would be to my advantage to be sure before leaving on that trip. I'm too close to 80,000 to take a chance.
Usually the cracked flex pipe triggers code P0171. Now it is plausible the flex pipe has cracked , so yes get it inspected and the connection to the second O2
sensor or have them replace it when they change the cat con
Either a wire is bad or the #2 sensor is bad. That's the easy one to get to. The wire is fairly long and can get close to the exhaust pipe.
There is a tiny chance of a cracked Flex pipe, but you should be able to hear that.
The #2 sensor only monitors the condition of the Cat con. So, you should be OK.
Replace with NGK/NTK, I would stay away from Bosch, I don't know why there are 2 Denso parts listed, I think one is the #1 and one is #2.
O'Reilly's has for my zip:
NTK - Oxygen Sensor
Line: NTK | Part # 21043
$77.99 Each
Shop around; I have seen them for much less.
NTK - Oxygen Sensor
$77.99 Each
I cancelled the trip tomorrow until I get this straightened out. Then of course the front end clunk will need to be checked out. But first things first...
Thanks I'll take a deep breath now! The problem I have is that at the end of the month there isn't much left from the social security check. Also since I am so very close to the warranty mileage and if I don't choose wisely which route to repair I take, I may cost myself lots of $$$
I'll check to be sure I have the right size tool and tomorrow see about getting that sensor they say is in stock....
Tell me about the $849 SS check and living in a wheelchair.
You will need to borrow their O2 Sensor wrench kit. Jack the car up on stands. Check the wires first, could be just a wire laying on the exhaust pipe.
Ah yes we're on a similar page for sure sad to say.
Thanks for suggesting I borrow the tool and check the wire first. With my luck or lack therof it won't be that simple though. LOL I have jack stands, car ramps and some solid rubber chocks so hopefully the weather will cooperate.
Well the weather hasn't cooperated with 5 inches of rain so far and still coming down. I need the car so I took it to a shop that I have used before. It's lucky that I didn't try to remove it myself because they told me it was seized and they had a real problem getting it out. I've started it about 8 times now and the engine light hasn't come back on. So far so good.
Now I am going to read the link about things that go bump in the suspension. It already has new struts though.
