Radioproblems
Old 11-09-2014, 05:18 PM
djtony's Avatar
Radioproblems
Why only one speaker works goes in and out back ones when ever they want to
djtony is offline
Old 11-09-2014, 05:23 PM
I don't know!
Mine work whenever I want them to.
donbrew is offline
Old 11-09-2014, 05:58 PM
Bad radio, speakers or connections. We can't "magically" tell you what your problem is over the internet.
You'll have to do a hands on diagnosis or get someone else to look at it for you.
EDIT: Could a mod please move this thread to the correct forum ?
firemangeorge is offline
Old 11-09-2014, 06:11 PM
Grizzly old man's Avatar
I had my own problems with the stock stereo in my '06 HHR. Its why I signed up here in the first place It turned out to be the stock speakers. A search, even on just this site, will give you a weeks worth of threads to read.
Since you said you do have one speaker that works when it wants to I can say with confidence that your still running the stock speakers.
You will need to replace them with other known good or maybe new ones. GM has been using special connectors on their speakers for some time. You will have to remove those to make most after market speakers work. Or do like I did and splice into the wires between the GM connectors and the radio.
I cut into the stock speaker wire about an inch above the stock connector for just in case someday I might fall into a deal on stock speakers again.
I put several different brands of speakers in my doors over a few months time. I've ended up with a cheap set from Walmart in there now.
They sound great. A neighbor bought an 2010 Cobalt with the premium sound system and my cheap speakers sound better than hers.
The really odd thing about my stock speakers is I put them in some home made enclosures and I still use them in my garage. Got no clue why they won't work in the car,...
Grizzly old man is offline
Old 11-09-2014, 07:29 PM
I would, but I don't know where.
donbrew is offline
Old 11-09-2014, 07:39 PM
LawDog88's Avatar
Probably where it is now in problems/service/repairs is OK.
If you don't figure it out soon, can you help us all with this problem wire up some Peaveys and let us jam with you?
LawDog88 is offline
Old 11-09-2014, 07:44 PM
Probably 'Specific Technical Discussions' in the sub forum 'Audio Video' maybe?
Old 11-09-2014, 07:50 PM
See? Easy isn't it?
I think whopper is in here doing things incognito
donbrew is offline
Old 11-09-2014, 10:19 PM
LOL - seems he had problem, and needs a repair....thusly, here it be....moved.....
whopper is offline
Old 11-09-2014, 11:59 PM
Yes, now the question is will the OP be able to find it if he bothers to come back to see what options have been listed or to report his 'fix'?
