Ran hot, then not, reduced power output....
I guess it won't make much difference at below zero temps. I went through the complete cooling system on my Land Rover, finding 2 bad cooling fans, intermittent relays, bad sensors, and electrical problems. The cooling fans will not kick in below a certain outside temperature so running the AC on max defrost will not make them run at -1 degree temperatures. and the fact I have no garage, It won't be warming up soon. Today's predicted high will be 13 degrees. a warming spell I guess.
When I was driving during November and the temps were much higher, the AC and cooling fans were functioning properly. Not that they may have failed since, but I can only test them when it warms up.
Upper radiator hose was full, parked on a 20 degree incline (neighbor's driveway) and the overflow tank was almost empty. I filled it up over the full mark yesterday before my 100 mile drive and had no issues.
I just went out and tried the start it and run defrosters on full and the fan did not start up. I tried my Land Rover and my son's 2021 Jeep with the same results. No fan. Overflow tank is in the same spot as yesterday after the drive.
