Rattle
Old 06-27-2011 | 08:53 PM
Lucky's Avatar
Rattle
I have had a rattle noise for a few weeks now so today I chased it down. it made the noise when starting out from a stop sounded like a sheild under the car. The problem was the air cleaner support bracket on the back of the air cleaner housing where it bolts to the exaust manifold worked loose causing the rattle from the loose braket. Tightened the bolt and all is good again. Just thought I would share this info incase someone out there has rattles they are chasing.
Old 06-27-2011 | 09:49 PM
Gee..... You are "Lucky" (pun intended) several guys have that rattle and that bracket has been rusted away.....
Old 06-27-2011 | 09:56 PM
bassic.sounds's Avatar
rear shocks
I just installed rear shocks on my '06 hhr. Can anyone tell methe torque specs on those bolts. I set the top bolt at 60 snd the lower bolt at 80 ft lbs.
Old 06-28-2011 | 01:13 AM
Service manual says 66 ft lb on the upper bolts, and 92 ft lb on the lower bolts. You can round down to 65 ft lbs and 90 ft lbs respectively without causing issues.
Welcome aboard bassic.sounds!
Vcode455
06-25-2012 10:41 PM
BeanWagon
02-03-2012 03:42 PM
alexrckid
12-01-2011 07:32 PM
HHRemi
03-26-2010 11:39 PM
jerij
07-08-2006 01:43 AM
Quick Reply: Rattle
