Rattling under the hood
Old 02-11-2011 | 05:31 PM
LawDog88's Avatar
There is a bracket directly behind the big plastic housing that has the air filter in it. What does it hold in place? maybe 2 inches wide at the most and and curls up from below..
I was standing outside at work, and heard a rattling from over by Stiglitz. So I think nothing of it. It's windy and I am working at a contract that is filled with scrap metal.
I walk over and put my ear near the hood, it's coming from inside..
I open the hood, and look around, checking things for looseness. Nothing..
I feel behind, and the rattling stops.. I look, and it's a bracket of sorts, as stated above.
Old 02-11-2011 | 05:47 PM
I think you are talking about the air cleaner bracket...... Only one I remember that's behind the engine.
Old 02-11-2011 | 05:48 PM
Lucky's Avatar
https://www.chevyhhr.net/forums/show...leaner+bracket Look here is this it?
Old 02-11-2011 | 06:09 PM
LawDog88's Avatar
must be. is it going to kill me if I leave that until I get my oil changed in the next week or so?
Old 02-11-2011 | 06:15 PM
TiggersHHR's Avatar
Mine broke just above the bolt hole on the passenger side. I took it off and had it welded back together with a little bit of reinforcement added. If you let it go - both sides might totally break off. If it is not securely fastened to the air box it could fall out under your vehicle and be lost.
Old 02-11-2011 | 06:17 PM
LawDog88's Avatar
Well dang. I have to get an oil change soon. Think I could have them tighten it down then"?
Old 02-11-2011 | 06:19 PM
TiggersHHR's Avatar
Found this on e-bay for $16 with free shipping.
Ad Title: chevy HHR air box support BRACKET
Condition: Used
Old 02-11-2011 | 06:24 PM
TiggersHHR's Avatar
I hate so say it, but you will most likely find out it is broken not just loose. There seems to be more and more HHR’s that are having the air box bracket breaking. The air box is a lot of weight for such a thin bracket to hold up.
Old 02-11-2011 | 06:25 PM
LawDog88's Avatar
it is just one piece. not two...
Old 02-11-2011 | 07:05 PM
Mrs. DLVRNIT's Avatar
Hey Officer1151,
If memory serves me right we think you reccomended another site member to go to the dealership for this exact same part to who was in need of one as his had broken! Here's a chance for you to use some of that knowledge as you probably won't locate one here .....
Best-O-Luck ,
Quick Reply: Rattling under the hood
