Rear Interior light bulb?
How do I get to the rear interior light bulb to change it without busting the lense cover. The light above the back cargo area is not working and I believe it's the bulb.
Thanks for any info...
Rear light bulb switch
Not trying to be smart or anything, but check the slide switch on the rear light. It can be bumped by cargo or something and get in a different setting or between either. Just a thought, happened to me once.
Tried that first, thinking that it did accidentally get bumped off. The switch doesn't work either way. I'm fairly sure it's the bulb. All other lights are working. I tried a small straight edge screwdriver to pry the plastic lense cover off but it doesn't want to come and think it may break if I try to force it.
Happy13178
05-14-2012 11:59 AM
