Rear left blinker not blinking
Old 09-22-2023 | 06:11 PM
Park's Avatar
The bulb works. I'm not sure if it's a fuse problem or what. Thanks for any help.
Old 09-22-2023 | 06:23 PM
greg8453's Avatar
Bulb works but don't work. What?
Old 09-22-2023 | 10:17 PM
to the forums!
not a fuse problem. Bulb, socket, or wiring. You have no idea how many times people are sure that it's not the bulb, and then it is the bulb. How have you tested it?
Old 09-23-2023 | 07:08 AM
Welcome to the site , check the bulb and bulb socket, look for melted plastic at the bulb holder. Be sure to install the correct bulb
Light Bulbs - suggested by 843de
- Headlamp Light Bulb Size: H13 (9008)
- Parking/Front Turn Signal Light Bulb Size: 3157LL
- Rear Turn Signal/Tail Light/Stop Light Bulb Size: 3057LL
- High Mount Stop Light Bulb Size: 921
- Fog/Driving Light Bulb Size: 9140 (non-SS) - H11 (SS model)
- License Plate Light Bulb Size: 168
- Back Up Light Bulb Size: 921
- Front Side Marker Light Bulb Size: 194
- Rear Side Marker Light Bulb Size: 194
- Map Light Bulb Size: 2825LL
- Dome Light Bulb Size: 562
- Trunk/Cargo Area Light Bulb Size: PC168
Old 09-23-2023 | 11:39 AM
PulpFriction's Avatar
For no good reason, I initially read the OP to mean the bulb comes continuously rather than flashing. Now I realize it's an ambiguous description. More typically, it doesn't come on at all.
Betcha we'll never know.
rmghhr
Maintenance and Upkeep
18
08-25-2023 06:43 AM
Adidas
12-30-2022 05:43 PM
227
10-28-2022 07:37 AM
RobV
05-28-2015 03:56 PM
bossrod
01-14-2011 04:49 PM
Quick Reply: Rear left blinker not blinking
