rear turn signals not working
2010 hhr panel, last week one of the rear blinkers quit working, today the other one did too, i replaced the bulbs and they are still not working, BUT when i put it in reverse both new bulbs come on like they should, what am i missing? i tried to check all the fuses that could relate to those lights... however i never found a fuse in the manual that specifically states it is for the rear turn signals.... please HELP!!!!!!!
Question........
When you put in in reverse, your tail lights AND the reverse lights (white) came on??? So you had a red and a white light on from both sides. Did you also check for the brake lights?
White reverse lights are the only thing working now.
Well, you are gonna have to get your hands dirty, or take it to a shop.
If you want to get your hands dirty, start checking the sockets for a good ground. If all the grounds check out, then you have a problem with connection(s) to power. And check all your fuses to the rear lights (check your owners manual for details).
