Rear wheels
I just changed out my rear hubs, I found that a 15mm deep socket 3/8 ths drive wobble extention, ( I have a 6 inch wobble so had to use a 12 inch extention to get thru the rear springs ) and my long handle 3/8 spark plug ratchet worked great to get the 4 nuts off!!
I determined the hubs had a slight grind noise when I turned the outer flange, and the outer flange was a little more then .003 loose!
