Rear Window Noise
Old 04-14-2011 | 07:35 PM
urbexHHR's Avatar
Rear Window Noise
Ok...so I noticed today that my rear passenger side window rattles when driving. I rolled it down, then up to make sure it was up tight all the way. When rolling up, when it gets near the top it makes a few clicking type noises. I tried watching as it was rolling up, but didn't see it binding anywhere..but that's kind of what it's sounding like.
Any ideas?
Old 04-14-2011 | 08:52 PM
BlackknighT's Avatar
Time to take the door panel off. Most likely splines in the window motor/tape are grinding...
Old 04-14-2011 | 09:08 PM
urbexHHR's Avatar
Ew...that sounds like something that I'll never be able to put back on right, or I'll break something...
Old 04-14-2011 | 11:54 PM
Eric- you posted about cleaning some throttle body part on your lumina.
I think you can remove a door panel..
Old 04-15-2011 | 01:14 AM
Originally Posted by sleeper
- I think you can remove a door panel..
DITTO!! Go for it man - and if you break it worse, you fix it. Thats how most of us learned.
Old 04-15-2011 | 04:18 AM
urbexHHR's Avatar
Yeah but plastic panels scare me. I just never have luck...always seem to break. I've removed door panels on the truck and Lumina before, but the HHR just has cheap plastic, and I'm afraid it'll break...lol
Old 04-15-2011 | 05:52 AM
LawDog88's Avatar
Haven't run across this, but has anyone noticed an air rushing noise from around the back hatch area??
Old 04-15-2011 | 06:08 AM
frank6060's Avatar
All you need is COURAGE Kid.. "Yes I Can"
Old 04-15-2011 | 08:17 AM
urbexHHR's Avatar
Ha ha, thanks guys! I probably won't attempt this just yet... My dad is out of state, and I'd rather he be here just for backup help if I need it.
Thanks for the support!
Old 04-15-2011 | 10:14 AM
Doctuh's Avatar
It will rattle
You can probably get the panel off and on again, but it will probably rattle when it's put back together!
Quick Reply: Rear Window Noise
