rear window switch broken?
the rear passenger window switch on the main drivers switch panel, you have to pull up on it ALOT harder than the other 3 for it to go up. works fine from the switch on the actual rear door. anyone else had this issue? im sure warranty will cover it, but i wanna finish my stereo install first so they dont see things taken apart and say that its something i did. it just started doing that one day like a month ago. this happen to anyone else?
I thought I was the only one. I thought I bent the stick for the lock. My driver's side door is starting to get sticky.
