rear wiper
rear wiper
when the rear wiper is in use and after it does the "wipe" then returns to its normal position, it kinda bounces back up the glass...happens when i flip the switch on and off to get a one-time quick wipe, falls back down to its "resting" spot then bounces sometimes just a little up and other times bounces almost to an upright position..any ideas?
haha ya i used to work at CT so i know how the system is sometimes wrong so i brought the actual wiper to the store with me and sized it up..so i do have the right one
Sounds like the wiper motor is going bad. The "park" position may not be engaging correctly. The wiper motor I believe is a non servicible unit. Have to replace the entire motor.
Hmmmmm. Any chance that the wiper arm is stripped or loose on the wiper motor shaft??? If so, then forget the 1st part of my post.
