Rear wiper arm R/R
B. Did you already use the SEARCH tool?
Wisdom has been conferred.
Follow the first three steps in post #2 of the thread linked below....
https://www.chevyhhr.net/forums/how-tutorial-library-21/rear-wiper-removal-mod-15427/
Moved the thread to a more appropriate location, if in doubt, start a thread in the "General HHR" section. It can be relocated if need be.
B. Yes I did.
Thank you for your infinite wisdom.
Well, then I will tell you what the procedure that I found 3 years ago when I searched was. Down at the bottom of the wiper there is a plastic cover that just pops off with a bit of gentle prying, then you will see the bolt that holds the wiper on.
So, I removed the nut and I can't get the arm off. There is a small amount of rust around the nut so I sprayed it good with WD40. It seems to be stuck on pretty good! Any tricks or tips on how to coax it off of there?
If you want to avoid risking damage, grab yourself a wiper arm puller, they're pretty cheap.
http://www.autozone.com/autozone/acc...ntifier=191681
Ordered a wiper puller, should be here in a few days. I hope it can do the job! This has turned into a real project! The thermostat was easier than this.
Thans for everyone's input, I do appreciate it.
