Rear wiper arm R/R
Old 07-21-2013 | 03:03 PM
scuba05477's Avatar
Rear wiper arm R/R
Any tips on how to do this job? Looks easy but have never done it. Looking for wisdom.
Old 07-21-2013 | 03:16 PM
A. Did you read the heading of the "tutorial library" section before you posted in it? Specifically the part that says this is not the place to post requests for help etc.
B. Did you already use the SEARCH tool?
Wisdom has been conferred.
Old 07-21-2013 | 06:47 PM
Follow the first three steps in post #2 of the thread linked below....
https://www.chevyhhr.net/forums/how-tutorial-library-21/rear-wiper-removal-mod-15427/
Moved the thread to a more appropriate location, if in doubt, start a thread in the "General HHR" section. It can be relocated if need be.
Old 07-22-2013 | 03:33 PM
scuba05477's Avatar
A. No I didn't.
B. Yes I did.
Thank you for your infinite wisdom.
Old 07-22-2013 | 06:33 PM
Well, then I will tell you what the procedure that I found 3 years ago when I searched was. Down at the bottom of the wiper there is a plastic cover that just pops off with a bit of gentle prying, then you will see the bolt that holds the wiper on.
Old 07-22-2013 | 06:37 PM
to be precise Don it is a nut that holds the wiper arm in place, seeing as we are being specific. but enough fun, off with the wiper arm and blade assembly!!
Old 07-24-2013 | 09:00 PM
scuba05477's Avatar
So, I removed the nut and I can't get the arm off. There is a small amount of rust around the nut so I sprayed it good with WD40. It seems to be stuck on pretty good! Any tricks or tips on how to coax it off of there?
Old 07-24-2013 | 09:44 PM
If you want to avoid risking damage, grab yourself a wiper arm puller, they're pretty cheap.
http://www.autozone.com/autozone/acc...ntifier=191681
Old 07-24-2013 | 10:04 PM
Only thing I could add is a rag and a screwdriver and patience. Those pullers may be good, you could always return it for a refund.
Old 07-25-2013 | 03:31 PM
scuba05477's Avatar
Ordered a wiper puller, should be here in a few days. I hope it can do the job! This has turned into a real project! The thermostat was easier than this.
Thans for everyone's input, I do appreciate it.
Quick Reply: Rear wiper arm R/R
