Rear wiper freeze!!!
Old 01-21-2007, 10:50 AM
Desert Coyote's Avatar
During Stitch's break-in period, the rear wiper left a swath right across the middle, regardless of how heavy the rain or whether I'd hit the squirter. After about ... oh, eight or nine months or so, the blade evened out, and it cleans excellently ever since.
Desert Coyote is offline
Old 01-28-2007, 11:31 AM
Bertland's Avatar
Ok they change the wiper motor, and it still do it, I check with the service manager, He told me that they will check with GM, here we dont have lot of HHR on the street, but it good thing to point out those probleme.
I will get back when I know more on what GM attend to to with that....
Bertland is offline
Old 01-29-2007, 12:43 PM
PITTSBURGH HHR's Avatar
Tell your Service Manager about Service Information Document ID#1751070. It concerns the "Rear wiper not working properly, it might swipe 2-3 times then stop at random at any place on the glass". It says to check the yellow wire terminal on circuit 5456 at C400 in the back headliner area. The terminal has been found to actually be attached to the wire through the insulation, not making proper contact. Striping back the insulation and crimping on a new terminal should fix the problem. Hope this helps. Keep us informed....
PITTSBURGH HHR is offline
Old 01-29-2007, 12:45 PM
Bertland's Avatar
Thank's I will check with them, and let you know what happen
Bertland is offline
Old 02-11-2007, 02:18 PM
Bertland's Avatar
See bottom post
Bertland is offline
Old 02-11-2007, 02:20 PM
Bertland's Avatar
Well that correct the problem, every thing is ok , thank's again for that info. The dealer took time to listen about the info and took good note about it for future HHR with same problem, thank's to them also
Bertland is offline
Old 02-11-2007, 02:58 PM
I'm now having this same problem. It will stop at a random point and a minute or so later start again, stop again, start again.....
It doesn't do it when I press in for washer fluid, it goes fine until the cycle is over, then its back to stop-n-go! Guess I'll be going to the dealer
GDZHHR is offline
Old 02-12-2007, 02:36 AM
Bertland's Avatar
Tell them about the note from Pittsburgh HHR, that what is your wiper problem, a small wire connector
Bertland is offline
Old 02-12-2007, 02:54 AM
Its printed and ready to go!
GDZHHR is offline
chichi
01-09-2011 06:10 PM
rgraboske
01-06-2011 08:32 AM
Carshowgirl
11-15-2006 01:16 AM
crowbar
45
08-10-2006 09:44 PM
Quick Reply: Rear wiper freeze!!!
