Reduced Engine Power problem
Old 05-01-2023, 09:20 AM
You had a "reduced eng pwr" and "service ESC" and "service traction" messages on the dash and ABS light but no CEL?
Who told you a wheel bearing or pulling a fuse?
I might suggest wheel bearing at the bottom of a long list, never pulling a fuse. My first suggestion would be look at the timing chain, then check all of the electrical connections that you had to touch while messing with the manifold and injectors; Especially the wire bundle that is tight against the purge valve bracket.
donbrew is offline
BunnyGirl
07-06-2014 01:16 PM
chevyalan
Maintenance and Upkeep
03-12-2013 01:17 PM
Cfpcsr
11-19-2012 01:53 PM
lizyness08
10-22-2012 02:20 PM
kornellred
01-09-2009 08:19 AM
Quick Reply: Reduced Engine Power problem
