Remote Control Not Working....
So, yesterday I went to unlock my doors with the remote, and for some reason, the remote is very touchy all of a sudden. The remote works sometimes, and other times it doesn't. It doesn't matter how close I am; I was standing right outside my driver's door and it still wouldn't work. But then sometimes it works without any trouble, and you wouldn't even know there's something wrong with the remote. So if it works sometimes, then it can't be that the battery (in the remote) is dead, right? Does anyone know what the problem is? Do you think I need a new remote?? Thanks in advance.
PS: If I try to unlock the driver's door with my key, the alarm starts going off. I can still get in and start my car (then the alarm goes away), but it's embarrassing when you're out in public. Is that defective? Is it normal for that to happen??
Sounds like the typical bad solder connection inside the remote. Here is a thd on how to repair. https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/ Now I also believe it is covered under the 3-36yr warranty and if that applies to you, take both your remotes to the dealer.
Sounds like the typical bad solder connection inside the remote. Here is a thd on how to repair. https://www.chevyhhr.net/forums/showthread.php?t=22641 Now I also believe it is covered under the 3-36yr warranty and if that applies to you, take both your remotes to the dealer.
Oh, I didn't know that. It caught me off guard the first time, I didn't even know what I did wrong. Then, the second time I realized it was because I was using the key. I didn't look in the manual though either.
If it's not the solder joint problem it could be the switch contact pads are wearing out.... there is a repair guide for this here on the forum...... I'll find the link after I wake up....
Where's my coffee?
Where's my coffee?
Maybe, Eric, sounds like there was a problem with those solder joints.... they shouldn't break at all if properly manufactured.
Here's the link to the switch contact repair thread...... Switch repair
One or the other should fix your remote, goetylsd......
Yeah, I guess that was kind of a weird way of writing it now that I think about it. Oh well.
