Remote start only works with one key fob
Old 02-18-2012 | 11:05 PM
BennieA's Avatar
Hey guys, 1st post. Great forum!
My wife just bought a 2007 2LT. One of the remotes works fine but on the second the start button will only flash the lights and honk the horn. Any thoughts?
Old 02-18-2012 | 11:50 PM
Tyler Harvey's Avatar
Welcome Bennie, could be the battery inside the remote? I know if you are only using one, (like me) the other has the tendency not to work, cause it's not being used (sounds weird). Could also be a circuit issue. Just saying this from past experience.
Old 02-18-2012 | 11:52 PM
to the forum BennieA!
My first thought is that the dealer or seller gave you a mismatched fob, but that would mean it wouldn't/shouldn't work any functions. I'd carefully take the offending fob apart and make sure there is nothing bridging the contacts on the circuit board.
You might just have a dud fob, but this is an unusual symptom.
Old 02-18-2012 | 11:56 PM
LawDog88's Avatar
Welcome Bennie!
Old 02-19-2012 | 03:30 AM
welcome Bernie to the site, that's a new one. If you bought it from a chevy dealer, I'd go whine. I got a couple spares I bought here programed, and they replaced one that the contacts were messed up, and called it warranty work.
Old 02-20-2012 | 06:31 AM
BennieA's Avatar
Thanks for the input guys. We bought it from a Honda dealer "as-is". Actually the remote that is working great now didn't work at all and it turned out to be cold solder joints on the battery clip. I fixed it the night we bought it and just figured it was a fluke. Then I saw the thread on here about that. Guess I'm not the only one.
Everything looks good inside this remote and the lock/unlock buttons function just fine. Maybe I'll check with the local Chevy dealer and see what they say.
Old 02-20-2012 | 10:37 AM
skyeglen's Avatar
Bennie, press the lock button, then within 2 seconds press and hold the lock and panic buttons at the same time.
I have 1 remote with a bad RS button, been using this method for a couple years. A lot of GM remotes will work this way.
Old 03-08-2012 | 09:34 AM
BennieA's Avatar
I've been a little slow to respond (or a lot), but this method works!
Thanks Skyeglen!
whoweth
07-01-2015 03:00 PM
maveric191
10-22-2014 08:18 PM
emill713
06-20-2013 10:27 AM
JJ Sparks
01-28-2012 03:49 PM
HillsdaleHHR
02-21-2009 02:26 PM
Quick Reply: Remote start only works with one key fob
