Remote won't respond, any last ideas?
Old 09-11-2012 | 07:34 AM
Mikeco613's Avatar
It appears to have worked! I will have to wait and see if it is a good fix but as for now, it worked.
Old 09-11-2012 | 12:50 PM
Gsus's Avatar
Hey I had the same problem, it was the key gum must be replaced after a while, the circuit works fine but the gum must be replaced. Or check the fuse for the door lock.
Regards
Old 09-18-2012 | 03:07 PM
alexrckid's Avatar
Originally Posted by AngelJ
Found this on another thread -
keylessfix.com
did this..!!! worked great. basically, i had to press the heck out of the remote(one, at least) to get the doors to lock/unlock. installed the product.........fixed. works like a brand new remote..........check out their web site.........
Old 09-18-2012 | 05:15 PM
happy to hear you got it fixed!!
Old 09-19-2012 | 09:10 AM
Mowgli's Avatar
Mine hasn't worked for months.
How do you swap the battery? I thought the fob was sealed.
Old 09-19-2012 | 09:18 AM
wmsburghhr's Avatar
pictures in this thd https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
Old 09-19-2012 | 09:28 AM
Mowgli's Avatar
Thanks for the link.
Both of my fobs have the solder joint failure
Will they be covered under the 100K extended warranty?
Old 09-20-2012 | 09:54 AM
@Mowgli, what type of extended warranty do you have? Is this warranty through GMPP?
Usually this is something that falls within the Bumper to Bumper limited warranty.
Old 10-17-2012 | 02:37 PM
HWD510's Avatar
Originally Posted by ChevroletCustomerService
How did the disconnection of the battery do for you?
I didn't disconnect the battery. I just started to work again on itself. I ended up buying the keylessfix thing and it really helps the remote work better. The buttons respond alot better.
Old 10-18-2012 | 11:36 AM
Thanks for letting me know what you had done to get this to work. I hope things will continue to work great.
Quick Reply: Remote won't respond, any last ideas?
