removing badging and emblems
Check this thread: https://www.chevyhhr.net/forums/show...t=remove+badge
Using a hair dryer to heat the adhesive really helps to 'soften' it up then those buggers should come off rather easily. You may have a bit of adhesive to remove after the badge is off. That comes off with a bit of WD-40 or Goo Off as mentioned above.
Desert Coyote
"How To" Tutorial Library
05-16-2017 09:17 AM
