Replaced Timing chain tensioner - now big problem
Old 09-16-2016, 09:29 PM
I guess you confused him, too.
Let's not make whopper change his oil again, please.
donbrew is offline
Old 09-17-2016, 08:17 AM
Jimmy68's Avatar
Originally Posted by Jim Wells
2006 2.2L HHR, I noticed a rattle every time I started the engine, I replaced the timing chain tensioner to the new style as recommended, the old one came out in pieces but nothing fell down inside, I primed the new one and installed it, I then turned the engine over and it rattled and spun, I am wondering if the chain either slipped off or broke, now the engine just spins and seems to have no compression holding it back, am I screwed?
Jim, my 08 2.2L was doing this and a month ago I swapped tensioner.
Same thing as yours. So I bought a New (used) engine and had that installed.
Old engine is junk. Good core.
Not saying your is but sounds the same. You bent your valves. Was cheaper to just swap engines with a low miler.
Jimmy68 is offline
Old 09-17-2016, 11:30 AM
Without the VVT
Oldblue is offline
Old 09-17-2016, 11:32 AM
With VVT note the Black exhaust solenoid and the grey intake solenoid
Oldblue is offline
hurst2001
05-17-2020 01:55 PM
prod
"How To" Tutorial Library
164
07-12-2018 08:20 PM
only1hhr
11-08-2014 04:50 PM
Lucky
04-25-2014 05:31 PM
Junior864
10-12-2012 02:39 PM
Quick Reply: Replaced Timing chain tensioner - now big problem
