replacement radio - missing chimes
When I bought my 2006 2LT, the previous owner had already swapped out the head unit. As a result, the car has no turn signal or headlight chime. Is there a module I can use to restore the sounds or would my only way to get them be to reinstall a factory radio?
Do not assume the absence of chimes and clicks is due to the radio install. A bad speaker will do the same. Prove the driver side front speaker works by isolating it using the radio's fade and balance controls. Do the same for the other speakers.
hzl6cm
06-01-2010 06:23 AM
