reversed polarity, alternator not charging
#31
the alternator or generator as its referred to in the manual was toast, had it checked.
i searched for hours in cobalt and other gm forums and found no one else with similar issue. im starting a stereo install thread and will show why i messed up. its in a tight space because of the subwoofer and was rushing at night.
#34
I'm glad to here your up and running. I was fairly sure that there was a fuse link there somewhere but I could not prove it. I did a lot of searching on the net for this post for other wiring diagrams.
I have found that automotive wiring diagrams are not always 100%. Changes get made in production and sometimes don't make it to the diagrams as they should.
#35
Thanks cannuck, I just added this information about J111 to my FSM for future reference.
By the way the FSM calls it a "Generator" as well in the wiring sections.
#37
My son did the same thing reversed polarity
This info wil be very helpful as my son just didnthis to his HHR. ALSO you can move the tensioner with a Craftsman 3/8 drive ratchet if its the low profile head. Its tight but it will pop in the square once in move it to about 8 o clock position and pull it slightly to slip the belt around crank pulley then using a friend pull the ratchet handle to 630 and have the person at the top pop the belt on the alternator
Dtaylor83
12-13-2013 01:12 AM
