Right Rear Door
Old 06-27-2007 | 01:41 PM
bisignano's Avatar
Smile Right Rear Door
Has anyone else had problems with the right rear door? I rented an HHR while my Vue was in the shop. I liked it so much I bought my own. The right rear door didn't close completely on the rental. I have noticed that the same thing happens on mine. My wife and I were driving down the road the other day and saw a very nice black HHR, and guess what, the right rear door was not closed completely.
Old 06-27-2007 | 01:51 PM
Navyflyer11's Avatar
I haven't had any problems with any of my doors. I have a 6yo who gets in and out of the back seat all the time with no problems.
Old 06-27-2007 | 01:52 PM
Wheelie7's Avatar
Hi There, Sorry, I never had a problem with any of Wheelie's doors not closing properly, but ten again, i hardly ever use the right doors..LOL
but If i had any problems, I would have taken it right away to my Chevy dealer for repair!
Old 06-27-2007 | 02:07 PM
solman98's Avatar
No issues with that here. They do have good seals, maybe the door is not getting closed firmly enough.
Old 06-27-2007 | 02:08 PM
Snoopy's Avatar
Try and determine WHY it's not closing tightly.
Try rolling the frt. passenger or drivers window down about an inch or 2. Then try closing the right rear door. If the problem is not present, then it's just air compression preventing the door from closing properly.....a little more effort will resolve the issue.
If the door still doesn't close properly BUT IS IN ALIGNMENT, try lubricating the hinges and lock mechanism with a DRY LUBRICANT.....I use Super Lube Dry Teflon Spray.
Had, what seems to be, the same problem with the drivers rear door. Lube and "cracking" the window solved my problem.
Old 06-27-2007 | 02:31 PM
the_shmoo's Avatar
Got to be the inside air pressure, have the same issue with my rear left door. Find that if I leave the front door open or crack a window open closes no problem. Watch your sun roof if you have one and you will see what I mean. Hope this helps. Air tight vehicle.
Old 06-27-2007 | 02:40 PM
Sometimes the rear driver's side door needs a little extra umph when closing it on mine.
Old 06-27-2007 | 03:19 PM
bisignano's Avatar
Thank you for the responses. I will try it. I just think it is funny that I have seen it happen on 3 different vehicles. The right rear door is the only one that it happens to. the other doors all close well.
Old 06-27-2007 | 03:28 PM
Snoopy's Avatar
Shmoo.....
The sun roof is a good point. It's funny how it "bounces" when you slam the door. A good indication of air compression.
Old 06-28-2007 | 02:47 AM
terry44030's Avatar
Wow! I thought it was just my Mother not closing the door all the way. She always has to close it twice, when getting stuff outta the back seat. Next time, I'll open a window a little and see what happens.
Quick Reply: Right Rear Door
