Ring singalong! The chimes
Old 02-23-2020, 02:27 PM
  #31
bailbud's Avatar
Originally Posted by Toyasock
Yes the recall was done bout 4 yrs ago I called the dealership and they told me it's been 4 yrs that they doubt it's the ignition switch and that if I brought it in and it's not then they will charge me 150.00
Yes I'm saying that when I take the key out of ignition and open driver door it chimes like key is still in the ignition if I put key back in ignition and turn it back and forth a few time sometimes it will correct and u can it the the click in the switch and when I open the door the chime is gone
your's sounds like the ignition lock cylinder, if by cycling the key you can get the alarm to stop . I just ordered one from rock auto for less than $50 , dealership was $125 . Looks fairly easy to change, lots of videos on line.
bailbud is offline
DrTrapper
GM Recall Campaigns
23
04-10-2014 12:27 AM
alexrckid
GM Recall Campaigns
04-09-2014 09:21 PM
ecpff
04-18-2013 07:56 PM
probablecause
03-26-2012 04:45 PM
Quick Reply: Ring singalong! The chimes
