Roaring sound help
Old 09-03-2016 | 09:07 PM
Glitzybabes's Avatar
Roaring sound help
I have a 2007 HHR. The car is making a roaring sound while driving and when you turn the wheel to the right, the sound gets loader. There also a bit of a vibration in the gas pedal. We changed the driver side wheel bearing and there is no change. We also over inflated the tires to see if the noise was the tires and there was no change. The noise started about a year ago and has got worst over time. Anyone know anything else it may be? Thank you.
Old 09-03-2016 | 09:11 PM
J W Davis's Avatar
Passenger side wheel bearing?
Old 09-03-2016 | 11:31 PM
We checked for play on the passenger side and it didn't have any.
Old 09-03-2016 | 11:45 PM
It doesnt necessarily have to have noticeable play to be bad. They arent like the wheel bearings of old. Was there any tight/loose spots or growling as you rotated the wheel?
have you rotated the tires to see if it moves?
Old 09-04-2016 | 07:56 AM
Axle?
Old 09-04-2016 | 01:36 PM
Rotated the tires and there is no change.
Old 09-04-2016 | 07:06 PM
Sounds like the right front hub bearing!
Old 09-04-2016 | 08:29 PM
IF you can feel play in the hubs, they have been bad for a long time. Most people can't feel .005 end play.
Old 09-05-2016 | 10:09 AM
It was the passager side wheel bearing. I watched a number of videos of people saying that if the noise gets louder when you turn right then it's the driver side. Well I guess that doesn't always hold true. There was no play in the tire or even the wheel bearing itself when we took it off and it has been bad for a while, I'm talking a year to a year and a half. Thanks for everyone's help and suggestions.
GinaM
05-25-2014 09:50 AM
SpaceCowboy
01-27-2012 02:28 PM
wraunch
03-18-2011 10:01 AM
jgoldwood
04-20-2010 08:43 PM
08BlkSS
04-13-2008 10:58 PM
Quick Reply: Roaring sound help
