Rotors ( Funny Sound)
Old 06-24-2007 | 09:13 PM
gtpman29's Avatar
I have these new rotors on my car when i go fast and then brake it makes a funny sound like something is vibrating also brand new pads and clue i got the rotors on ebay they are Front Drilled & Slotted Rotors
Last thing should I torque the front wheel nuts and if to what do i do them to
Thank you guys for all the help
Old 06-24-2007 | 10:07 PM
Dave C's Avatar
Lug nuts torque to 100 lb ft on clean and dry threads.
Did you break-in your brakes before high speed driving or heavy braking?
Old 06-24-2007 | 10:19 PM
Size:  5.6 KB to the site!!! Not sure what's wrong but apparently something is.
Old 06-24-2007 | 10:26 PM
Black Rose's Avatar
The preceding post has been brought to you by Captain Obvious
Old 06-24-2007 | 11:21 PM
Dan's HHR's Avatar
to the forum and brake gently
Old 06-25-2007 | 03:31 AM
MrVette's Avatar
Turn up the stereo, the noise wil go away.
Old 06-25-2007 | 03:35 PM
TomsHHR's Avatar
the slots could be making the vibrating noise you are hearing. could be the newness..
Old 06-25-2007 | 03:41 PM
Snoopy's Avatar
along with the torqueing spec's and tightening the lugs in the "star" pattern, make sure you clean the mating surfaces of the hub and rim very well....use a wire brush on rust and dissimilar metal corrosion.....as per GM's TSB. Also, either remove or be extra careful with the retaining clips found on the hubs. They have been know to cause problems such as you discribe.
Old 06-25-2007 | 08:25 PM
DreamHHR's Avatar
Is it funny good or funny bad?
I had cross-drilled rotors (front & back) on my last car and they often made a faint "wizzing" sound, especially when cold or wet. It was perfectly normal in my case, it was just the sound of the holes passing by the brake pads. There were no actual vibrations though.
Yves
Old 06-25-2007 | 08:58 PM
See what 70 hours of work and 16 hours of driving in one week will do to you
Quick Reply: Rotors ( Funny Sound)
