Scratches on my Window Tint
Has anyone ran into scratches on their window tint of their HHR. I plan to remove my door panel and see whats going on. Can anyone tell me if there is an area inside the Panel that causes this.. I
It could be something as simple as dirt trapped in the window "felt", when you pull the door panel carefully clean the felt, and you'll probably cure the problem. Unfortunately the tint will still be scratched unless you replace it.
They are a great tint shop and have been a customer for years..
Some folks will remove the inner felt with aftermarket tinted windows, but that almost guarantees that the glass will either rattle like mad, or it will eventually work itself out of the channel when you least need it to happen...think monsoon rain with the window down.
I had the beginning of a vertical scratch on my drivers window (obviously from something inside the door panel) about 2 months after I had the tint done. After going back to the tint place I found out they went out of business....I was even going to pay to have it corrected and redone.
Anyhow, it has gotten more pronounced after about 5+ years. Might need to go elsewhere.
my panel I tinted right after buying it & no scratching to date..
However my former '98 S-10 that I tinted & after a few yrs was getting the beginnings of scratches on driver side. I just took my air hose & shot air down between the felts & glass inside..
No further scratching occured. Was just some trapped dirt it seems.
So periodically I use the air hose on my panel fr glass/felts.
HillsdaleHHR
19
08-20-2009 10:35 PM
