security horn disable
Old 05-09-2012 | 01:48 PM
bilko's Avatar
I have repaired the key fobs numerious times. I do not want to buy a new one.
How do I disable the horn, when I open the door with the key?
Bilko
Old 05-09-2012 | 03:20 PM
There will be times (Dead battery in Key Fob) you will need to unlock using the key.
To disarm the alarm using the key:
. . . 1st turn left and unlock
. . . 2nd lock the door. Locking disarms the alarm.
. . . 3rd unlock the door.
you can now open the door without setting off the alarm
To arm without the Key Fob, just power lock the doors using the control beside the door handle.
Old 05-09-2012 | 04:10 PM
bilko's Avatar
Is there a way to disarm the alarm so the blound ("opps I mean the wife") can unlock the door without thinking?
Old 05-09-2012 | 04:14 PM
Simple answer, nope, not really.
Old 05-10-2012 | 11:56 AM
jimpennjr's Avatar
Thanks 843de, I was wondering how not to wake my neighbors. My keyfob contacts barely work. Replaced battery and solder is good. I ordered a new casing, hopefully have tomorrow.
Old 05-11-2012 | 02:43 AM
If it is just that your contacts inside are dirty - give them a cleaning with some alcohol and a q=tip, and/or check https://www.chevyhhr.net/forums/how-tutorial-library-21/repair-key-fob-remotes-worn-out-contacts-30813/ - I rebuilt my fobs almost 2 years ago, and they are still going strong.
You can also order a replacement keypad on the internet.
Old 05-11-2012 | 06:22 AM
jimpennjr's Avatar
Thanks whopper, that is on my list of things to do. Already tried the alcohol cleaning. Using a old remote to repair is on the list. Thanks again, Jim
Old 05-11-2012 | 08:19 AM
jimpennjr's Avatar
New remote case and rubber inside came today. Ebay $2.50 shipped! Awesome. I love eBay.
Old 05-16-2012 | 05:37 PM
bilko's Avatar
I followed the above directions and it worked once.
Unlocking this way, with the key, works less then half the time.
Old 05-16-2012 | 08:13 PM
My experience is: use the key to lock then use the key to unlock no alarms. Use any other method to lock then unlock with key causes alarm. YMMV.
Quick Reply: security horn disable
