Service ESC + Service Traction + lock icon appearing on dashboard
Old 11-06-2020 | 01:41 PM
  #61
TechBill's Avatar
Nearly a month ago, you said you were going to check if the battery terminal(s) were broken. You have not reported on that.
All these things that you say you checked, are you just visually checking, or are you testing?
Sorry been busy ..
Battery terminals had been check and cleaned .. look fine and no issue with it
Old 11-06-2020 | 01:44 PM
  #62
TechBill's Avatar
Originally Posted by Oldblue
I see in post #14 the ground wires are tight, but you do not indicate they are clean! Did you take them apart and clean any corrosion off then tighten them back up , preferably with a little dielectric grease.
I watched the video , seems like a loose or broken wire , the multiple warning lights on the dash board, also indicate a low voltage battery issue, anything under 12.4 volts will cause this type of problem, and or a dead cell or 2 in the battery.
We bought a brand new battery .. same result .. dashboard sitll going crazy and dashlight coming on and off like security, brake, with a text message to check ESC appearing across the dashboard.
Old 11-06-2020 | 01:49 PM
  #63
TechBill's Avatar
A GM mechanic (friend's boyfriend) came by a week ago and we disconnected every ground connections and we used a brass wire brush to clean it out really good. it still did not fix the issue ...
He starting to think it the BCM but without Tech2 tools, he couldn't confirm it. He said his shop cost me an arm and leg to scan it due to the value of the HHR so I am thinking of getting something like this
Amazon Amazon
to scan it and if it shown to be bad then get another one from junk yard and a subscription to get the firmware to flash it myself.
But he is puzzled why dashboard kept saying service ESC so he couldn't pinpoint the issue since he doesn't own the shop or the tools to scan it with. He just work for them.
Old 11-06-2020 | 04:05 PM
  #64
If everything is going crazy, that’s normally a sign that there is to low of voltage in the battery, have it load tested, under 12.4 bolts will cause issues.
Old 11-06-2020 | 04:07 PM
  #65
TechBill's Avatar
We have brand new battery in it ..
Here the post about our HHR - Still driving us crazy now for like 5 months?
https://www.chevyhhr.net/forums/prob...shboard-63338/
Old 11-06-2020 | 04:09 PM
  #66
The service ESC notice can also be from a short in the fuse box , have you inspected the under hood fuse box for loose halves, bent pins , a stray strand of wire from an add on?
Ive merged your posts here, let’s keep it in one thread, easier to find and follow
Old 11-06-2020 | 04:29 PM
  #67
TechBill's Avatar
Yeah, in several post back. I explained that I took the fuse box apart and also disconnected all the connectors on ESC and BCM too then use an electronic spray cleaner to clean all the connectors. It didn't solve the issue.
We are still driving around in it everyday I guess you were call it limp mode when it kick into that mode and out. Money is tight and local mechanics doesn't want to touch it so meaning only dealership would be willing to look at it which mean $$$$$$$
Old 11-06-2020 | 05:32 PM
  #68
"Service ESC" just means the EBCM is not getting enough power to function, it rarely has anything to do with the actual ESC, especially with all of those other lights.
Old 11-06-2020 | 05:36 PM
  #69
I see those posts, thanks, one of the reasons we will keep to this thread.
Old 11-07-2020 | 08:51 PM
  #70
TechBill's Avatar
is there a way to check oh EBCM is getting enough power or not? I have a voltmeter if you can point me to the right direction to measure it at
Thank you
Quick Reply: Service ESC + Service Traction + lock icon appearing on dashboard
