Service ESC traction control
Not sure where to put this question but I replaced the camshaft position sensor today on my 2009 HHR today and afterwards the light came on for the anti-skide or traction control feature and the instrument read out says "Service ESC" anybody know about this? I have no idea how to fix this. Thanks
I moved you into your own thread. It will get better responses this way.
Did you replace the sensor or the actuator solenoids? Most of the time the solenoids are causing the problem but the part stores sells people the sensor.
If you can post the codes that you had before the repair.
Fox Hat
02-07-2014 07:39 AM
