Solenoid not engaging after motor rebuild
2006 lt 2.4 automatic. Starter and batter fine, checked.
Power to starter main, not to solenoid.
Tried transmission in all positions with shift rod off and on.
Pulled and pushed all connectors a few times.
Crank relay and crank/run both hot with key in start position.
Park/neutral has power.
What am I missing?
What am I missing?
If it's the original engine that was rebuilt, and was removed from the vehicle and reinstalled, double check all electrical connections, including all the grounds, making sure they are clean and secure (dirty connections just don't cut it, and the grounds seem to be the issue quite often as they are mostly exposed to the elements).
Cleaned and sanded and made sure they were tight. Block to frame, block to wire harness, near fuse block to body. Nothing still permitting signal to solenoid wire which I have a test light to off of the starter.
