A solved problem and a possible hint for other owners.
Old 07-04-2010 | 12:09 AM
ZTony8's Avatar
The other night leaving work the check engine light popped on.I brought it in the next morning and the canister purge solenoid was found to be sticking.The car has never run all that terrible and has always given great mileage.But it's always felt like it was running very lean on acceleration.Now it doesn't so I think the canister solenoid has been acting up for a while but only stuck enough the other night to finally trip the code.The lesson here? If your car feels like it's "holding back" on acceleration(mine's a 08 2.4 5 speed) it might just be the canister valve.
Old 07-04-2010 | 12:48 AM
Tony-
Good info, Thanks for posting it..
Old 07-04-2010 | 01:32 AM
Stryker's Avatar
Okay...so how does one check the "canister purge solenoid"? :)
Old 07-04-2010 | 03:26 PM
ZTony8's Avatar
You'd check for a stored code P0496 with a Tech2 scanner and/or test the evap system.
cosmic1
04-18-2011 09:47 PM
hyperv6
11-25-2008 06:00 PM
TyroneMD
2.4L Performance Tech
10
09-23-2008 08:42 AM
SSROADSTER
06-24-2008 06:41 AM
jerij
12-15-2005 06:31 PM
Quick Reply: A solved problem and a possible hint for other owners.
