Something strange
Something strange
Today when I started the HHR it started as usual then as I was putting my seat belt on it stalled.
I finished clicking the belt and hit the switch again and it would not start. It was cranking fine just not starting.
I poked the DIC button a few times and got no codes no Check Engine, nothing.
Not knowing what else to do I opened the hood and looked at the fuse box up there then looked at the fuse box by the passengers seat.
Naturally I could see nothing wrong.
So I scratched my head a while and tried to start it again. It fired right up no problem. So I put the belt back on and went on my merry way.
I decided to swing by the Auto Zone store and have them put the code reader on it. {its free even if you don't buy anything}
There were no codes stored at all. Like I said I just went on my way like I normally would, shutting the engine off and starting several times and no problems at all.
So with no problems that can be detected I'm just a tad worried that there is something really wrong that will rear up and bite me soon.
I'll keep y'all posted if something does come up.
Just for fun I pulled and reseated all the fuses and relays.
The problem has not repeated itself so its probably nothing to worry about at all.
Just enough to keep me interested I guess.
It may not have read the ignition key correctly, or at all. I have had mine do that a couple of times, pulling the key out, re-inserting it and it has always started right up. Not sure how great a reader that switch has.
I don't own a scanner myself. Too pricy to justify for no more than I would be likely to use it.
Unless the car is dead on the side of the highway and and I was trying to figure out what was wrong before the tow truck got there I don't see a real need for one.
So far it has been easy enough to go to Auto Zone or the dealer we bought the car from, when I decide to look for a code.
So far I really haven't had any problems. The first time I had them hook it up I was just curious if there were any lurking around and there was nothing out of the ordinary.
I have however looked at a GM tech 2 because your supposed to be able to tell the car to accept a different GM radio if you want but again so far that's just too much money for me to part with.
I had one incident about 1 1/2 years ago. I stopped at a stop sign and the engine died. It would restart but immediately stall. After a few cycles of start/stall it was fine and it never happened again.
Steve
Steve
