Sort of funny noise from engine?
Old 10-13-2007 | 09:43 PM
Goose's Avatar
Originally Posted by stelerz
I Hear A Kinda Jiggling Noise Like A Rattly Chain When I Eccelerate. What's What That?
Sounds like my noise...injectors crafty? If so how come only when warm??
Goose
Old 10-14-2007 | 04:10 PM
Premiere07's Avatar
Originally Posted by Lone Ranger
No additives for my HHR's oil, here a gig on Lucas Oil Stabilizer:
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Sorry, but that is one biased opinion talking about oil being used in an industrial application that uses gears to "pick up" the oil.
We have an oil pump with a pickup in the oil pan, and in general a totally different method of lubrication delivery throughout the engine using pathways and channels, as well as utilizing pressure from the pump to move the oil around to areas needing lubrication.
Although, I can respect that YOU don't want to use additives don't over generalize "tests" and "theories" you see on the internet. Anyone can open up a website and call themselves an expert on anything, that doesn't necessarily mean that it is true.
I was just stating what I had done and expessed that it worked for me and it is worth a try if they want.
Old 10-14-2007 | 05:33 PM
hhrcrafty's Avatar
Goose
I dunno. Every MFI car I've had for the last ten years has had the same noise after warm up, though. Never had to replace an injector, though.
Old 01-02-2008 | 07:57 PM
442dude's Avatar
Hi All,
I know this is an old thread but my Ecotec does the same thing. Odd that you only hear it after the motor warms up. Its almost a clacking noise. Did anyone ever find out anything other than that it was normal?? Just wondering. Thanks.
Old 01-02-2008 | 09:51 PM
hhrcrafty's Avatar
It could be just a little piston slap or rattle too. Our pistons don't have a deep skirt to reduce friction and the rings have to work harder to keep compression as a result. The piston can "rock" a little as it moves up and down and that extra vibration can cause an audible rattle as well.
Old 01-03-2008 | 07:24 AM
  #26
442dude's Avatar
Think its something I should be worried about??
Old 01-03-2008 | 07:34 AM
  #27
hhrcrafty's Avatar
Nah. GM's been doing their engines that way for the past eight years and none have failed because of the new design. It's just another way of gaining power and fuel economy by reducing the friction in the engine, but it makes for a noisier engine. Some people have gotten real irritated and sued GM over it, but I don't think anyone's won anything yet.
Old 01-03-2008 | 07:48 AM
  #28
442dude's Avatar
Thanks Crafty...BTW, its in an 04 Saturn Vue, I don't have an HHR but since a lot of the mechanicals are similar I enjoy browsing here as well. Since I've got plenty of experience under the hood, hopefully I'll be able to help someone here as well...Appreciate the help!
Old 01-03-2008 | 03:02 PM
  #29
Alzonie's Avatar
Originally Posted by SandyBeach
I think you need to turn the radio up. I don't hear any noises!
That always works for me too!
Old 01-07-2008 | 07:03 AM
  #30
robbob's Avatar
Hi,
I'm new here. Just wanted you to know that I had my new HHR back to the dealer last week for what I thought was a lifter noise. I also only heard it from inside the car which I thought was a little wierd. The service advisor told me that all the 2.2 ecotec engines have that noise and it's nothing to worry about. Hope he's right. Looks like I do what eveyone else does.....turn up the radio.
Alexwsilver2010
09-09-2012 03:04 PM
jomack
01-26-2010 05:45 PM
AaronSS
10-01-2008 01:41 PM
Daverb
09-17-2008 08:14 AM
Motormike
07-30-2006 12:40 PM
Quick Reply: Sort of funny noise from engine?
